I used the Canadian OEM which seems the best of all worlds. No tapping into wires, no insulation damaged. You have to insert the power pin into an existing harness, and you have to thread the 4 flat wires in from the outside before you snap them into their connector. No running a separate power line to the battery.
The included bracket fits the holes that Studum suggests.
Mm.. no need to tap with the Canadian OEM, sounds like a good option. I will have to look into that!
