- 2016 Mazda CX-5 Touring AWD, Moonroof/ Bose and Tech package
I know this question has been asked a few times on how to get to the command knob area in the 2016 CX-5 for cleaning. If you need to take apart the console, see this how-to: http://www.mazdas247.com/forum/showthread.php?123856681-2016-Center-Console-Removal
So, if you though that getting to the cabin air filter was easy, try this!
Step 1: Clear out your cup holders, that other little area next to those (I keep gift-cards and a tin of Altoids there), and remove the little tray in the center console storage.
Step 2: Pull the trim straight up at the yellow marks indicated below. Then pull straight up where the red indications are.
Step 3: Do whatever it is you want to do. Be sure to disconnect (and reconnect!) the cables going to the command knob and the E-Brake (and you should disconnect the battery before this) if you need to remove the trim from the location. Then open a nice cold beverage and enjoy your work!
(Note - flip over the piece you removed and there are 4 screws holding the commander knob parts (with the "shiny" trim) to the rest.)
How to for the rest of the 2016 center console removal: http://www.mazdas247.com/forum/showthread.php?123856681-2016-Center-Console-Removal.
