2011 CX-9 airbag warning light question
2011CX9 Touring
Airbag warning light came on and it flashing a code of 2 flashes pause then 3 flashes. Took it to stealership and they said almost $3k to replace airbag control module and passenger side sensor.
Anybody know what this code is? I looked it up but did not find one that matched that pattern. Will check wiring later when I have more time. Thanks!
My OBDII does not work with airbag warning light. I need a different scanner that can read the code. I went to Autozone and they used their OBDII and could not get the error code either for the airbag light. All I can go on for now is that flashing pattern.
Upvote 0
