I have a 2003 Mazda6i 2.3 This car has run rough over the last year and I have not been able to fix it. Mechanics (Mazda dealership and general mechanic) have just reset the codes and fixed the usual suspects (non-existent vacum leaks), problem remained.
Here's what is does runs rough especially at idle, smells very rich when first start, it can (rarley but suddenly run a little smoother over 40 mph), low power always, misses. The codes have varried over the past year but usually to do with a misfire, lean bank, mass airflow sensor, cam sensor. Right now the codes are P0300 and P0340.
What I have done replace coil, plugs, wires, mass air flow sensor, CPM Sensor, checked EGR Valve, vaccum leaks all fixed. Considering O2 or Cat??
Any help would be appreciated.
