Ok, hoping someone here can help me. I have a 2003.5 Mazdaspeed Protege with the following problems. Low boost around 2 to 3 pounds in the higher rpm range. I have no boost leaks as I have done 3 boost leak tests. Wastegate is new and it works. BPV works. Turbo spools and is not making any sounds, has a very small amount of shaft play. I hear the whoosh sound coming through the Injen CAI. I have installed a new exhaust manifold gasket, new spark plugs as well. I'm getting a p0401 and a p0307 code but really don't think this has anyting to do with boost, correct me if I'm wrong. The last catalytic converter is bored out due to it having had some lose paticals inside.
Tests performed.
I took the bpv off an blew into it and air was not getting through.
Applied air to the turbo inlet pipe (cold side) holds pressure. As I remove the tester I can hear the air release, so it's holding boost. Did not here any leaks what so ever.
Sprayed soap and water mix to find bubbles, none detected.
Removed vacuum hose connected to wastgate and ran car, still 2 to 3 pounds of boost.
Applied air to wastgate actuator and the rod moved.
If anyone can help me I would greatly appreciate your help.
P.S I'm a new member here and all I know in regards to turbos, is what I have read online. Thanks.
Tests performed.
