1991 Mazda Protege
dallen
Divers side power window is stuck down. Switch is broke. Called alot of salavage yards in SE MI and NW OH and no luck with finding a switch. I would like to bypass the switch if I could. There are only two wires running to the window motor tho. Please help if you can.
Thanks for your time.
If you put power to 1 and ground the other it will go up, reverse and it will go down.
I have a master switch in perfect working shape you can have. Was going to destroy it for parts, but later found out its alot different in design then my 88 GT switch. Let me know if you want it.
Latest posts
