2k2silvermp5 said:So what offset is the best to go with??? 48mm??
flat_black said:A zero offset rim would have the mating surface of the rim to the brake face at dead center. A +10 offset would mean the wheel's mating surface would be 10mm closer to the outside of the wheel, the part you see. A -10 offset would mean the wheel's mating surface would be 10mm closer to the inside of the wheel, which is the side you can't see.
Make any sense? =)
flat_black said:No big deal. =) I'll draw you up an illustration: Gimme one sec...
