bikingpro5
- 03 Protege5
1.8 set up is a waste of time
not sure if its a complete waste of time, i do know that it was a cheap replacement for our OE coils and IMO look much better then the OE coil on plugs.
Yes it look's good, but i'm not sure it would be good for the ECU
those are all OEM replacements. Hell, you can pick those up at any auto parts store. To clarify, if it was a requirement to use coils, there would more than likely be a performance upgrade for our cars out there, which there isn't. People have been using the 1.8's for a while with no problems. If there was any issues with these being used with our ECU, they would have been discovered only a few hours to a day or so after the first person tried using the 1.8's.
wow this is very interesting because i was wondering if i could do away with those slave coils. my msp throws a p0300 every 3 or 4 days, was thinking it could be those coils either going out or just getting hot. i have brand new ngk coppers gapped at .030. goin to get the reflash done on tuesday and if that code keeps appearing goin to look into this swap alot more
Limited knowledge but the ecu is only using the coils to start the discharge of spark to the plugs.. As long as the plug from the wiring harness hooks up to the coil pack it should spark the exact same.. The pack itself shouldn't have any control of when the spark is sent
