My 08 5 with 40k miles has developed an odd problem. Every so often, getting more and more common, it stumbles and nearly stalls while braking to a stop. It never stalls, but the power drops off, the EPAS warning light goes on as do some other warning lights. Also, the center display (where the radio station and air con information are displayed) flickers and shows the start-up "Hello!"
My wife mentioned it a while ago and I've finally seen it do it a few times to know it's not a fluke anymore. But the other day, it was really bad. I was pulling into a parking space when it did it and it kept doing it. So I sat there for a minute in park and played with it.
- Idle speed drops off enough to cause warning lights and flicker, EPAS goes dead.
- Blipping the throttle causes it to go away, but starts again as engine speed reduces.
- Went away after a minute or two and didn't happen again during my short errand.
- No A/C or lights on at the time, seems to do it regardless.
I have a Mazda manual at home, but it will be a few days until I get home. Doing a quick search shows this seems to be an issue with the 2.3. The battery was replaced about two years ago and no problems until about 3 months ago. This is an 08, built outside the TSB for earlier cars and it was bought new, there have been no other problems like this.
Finally, I have the Mazda remote start installed and was wondering if I should suspect it as well.
Thanks
Thanks
