FMOS Racing
- 2008 MS3, plus a pickup and a beater car
Too much power at 85% throttle?
well if its true or not he will never know. whole car is ****** he rolled it. rim and rotor came right off
85-to-90 then gradual floordoes work
i think flooring out the gate may throw too much fuel and isnt mixing with enough air.
If you just WOT shift at the right RPMs, wouldn't that be faster than the 85-90 throttle?
The old Mazdaspeed Protege used to have the exact same problem it accelerated harder under partial throttle than just flooring it. Usually.
It's to do with how the turbo spools. Turbos work better under load, so they actually prefer a little bit of resistance when sucking air in. A gradual ramp up is and always has been the best way to drive a turbo car and trust me i have driven a LOT of them.
I do find that once the motor is good and hot the best way to drive it if you want to feel the greatest acceleration is to slowly feed the throttle in getting close to 80% at 4000rpm then flooring it at 5000 or so. Your metering the fuel with your foot. The idea about too much fuel is probably correct. You need to match the fuel with the amount of air going in.
But yes gradual increase = better turbo response. More often than not.
maybe one had VTAK
