Seems my 06 5 sport is quite the anomaly. It has ZERO issues with rear tire wear, however my front wear is HORRENDOUS! Seems the opposite of what I read everyone with an 06-07 has?!?! Factory toyos got me to 27k before a HUNK came off the front. Backs still had 80% but we put on a new set of Yokohama's they came very highly recommended. The were the 2nd most expensive tires in stock behind only the Michelins which I REFUSE to run ever due to their crappy rubber that cracks in under 2 years on the sidewalls. Anyhow, I am at 10k on the yokos and fronts are down to the wear bars. Rears are still at 85-90%.
Any ideas? car is driven like a grandma. New kyb shocks/struts at 30k. Aligned by best shop in town and they said it was dead on. Tire pressure kept at the max. 99% of the time 1 lighter person is in the car. I can count on 1 hand the number of times anyone has sat in the back, only had to use the 3 rd row 1 time when the car was 1 month old (Maybe that is why the rears don't wear out? no one ever sits in the back 2 rows?). Anyhow I realize there is a toe kit to fix the rear wear issue, but I don't see this issue on mine at all, so I don't see the point? Unless it would somehow affect and fix my front alignment?
I understand the importance of rotating tires, but honestly it is better for me to NOT rotate them with wear this bad, as I only have to replace 2 tires at a time, and I get the high prorated discount off the next pair. I go in there with 10k worn out tires I get a huge discount compared with 4 worn at 27k.
