Just got off the phone with the guy I purchased the car from. He said the motor came from a car with abs but the trans did not come from a car with abs. Would that make any difference?
That means your transmission should have the speedo gear, and your harness should have the connector on it to plug into the speedo gear.
The connector on the harness may be different and may need to be changed.
Check your harnesses and look for connectors that aren't plugged in to anything.
