whatusername
- 02 protege5
weird thing going on before i turboed my car a few days ago oils pressure was 85-90 psi cold around 22-25 psi warm and around 12-13 psi fully warm now after the turbo install i get 85-90 cold 22-25 warm and 0-1 psi fully warm at about 700 rpm only thing i did was add the turbo kit and ran the oil feed line thru the sandwich plate... im thinking mayb the oil feed line is sucking the oil to the turbo on idle so the gauge cant get an accurate reading on idle????? also my bov should be on hot pipe or cold pipe?
