Alignment problems on lowered P5s?
PR5Matt
If lowered about 1.5" what part of the alignment s out of spec on the P5?
I figure the toe is out, but how bad is everything else.
the camber isnt bad on our cars, mines about -1 degrees. helps cornering if anything. the toe is what really needs to be corrected
I had like 2 degrees of negative toe when I had my alignment done. Only problem is I waited like 2 weeks to get the alignment and totally destroyed the inside of the front tires..........
PR5Matt said:
How bad was yours off?
