p5sundevil
- 03.5 MidnightBlue p5
OK, Now that we have this awesome forum to be more specific about NA tuning I thought we should have a good thread covering all the options out there and their basic qualities.
As a disclaimer because I want this thread to stay on topic this is NOT a discussion about what kind of header is best, because that depends on your goals and personal taste(as well as financial reasons but we will try to stay clear of that)
So basically I want this to be as factual and clear cut as possible. Ill list all the header applications available to us that I know of, PLEASE add any that I miss or comments on the quality/customer service behind each piece. Not about whether you like a 4-1 or 4-2-1 better.
here we go....
AWR: Of course the first widely available header for our cars. A 4-2-1 full length tubular header. made from 304 SS and TIG welded all the way around comes with 2 o2 sensor bungs and an EGR valve and bolts directly to the stock midpipe with cat.
*note: fitment issues have been found with automatic proteges, should be fine for manual*
Goes for about 565 shipped... www.protege5online.com
Other pictures can be found here.....
http://www.protege5online.com/For_Sale_Page/AWR_Header/awr_header.html
Wagner Motorsports: Wagner makes a 4-1 style shorty header that bolts directly to the stock primary cat making an emissions legal header.Goes for $185 in steel and $265 for SS. Comes with all EGR valves and so forth and according to wagners website it has been dynoed for a 7whp gain, no dyno scans available though.
Pictures Here: http://www.wagnermotorsports.net/productDetails.php?id=16
*note: Wagner also offers a SS Downpipe with or without a cat in it that can be added to the header in bolt-on fashion. This will allow you to choose to retain a primary cat but have it better flowing or to eliminate it with the downpipe. Also available is a midpipe with or without cat to further complete the exhaust system.
Ractive: This is different from the wagner and AWR headers in that it is a mass produced item and not handmade. This makes cost lower but as some will tell you quality will not be the same as a handmade piece like the two above. With that said this is an equal length 4-1 header design made of SS and tig welded. Bolts directly to stock midpipe with cat eliminating the primary cat. Has egr valve and O2 bung but will require you to add a 2nd O2 bung behind the 2nd cat or get a MIL eliminator to prevent you from having a CEL show up. Available for around 200-250 shipped depending on the vendor.
*note; Ractive currently makes an axle back exhaust with a midpipe in the R&D phases to eventually complete their exhaust system setup for the proteges.
Pictures to come:
Essential Speed: ES has 2 header options available as of right now. An equal length 4-1 shorty style header that retains the stock cats. 304 SS comes with EGR and O2 valves, ceramic coating is included which is real nice and according to their information that have seen 8-10whp gains from this shorty header although dyno scans are not available. Goes for about $600canadian which is about $438 USD
Picture:
Es's second header option is also an equal length setup but is a full 4-2-1 design that eliminates the stock primary cat.This one is also SS and ceramic coated by ES, comes with midpipe>hi-flow cat,flexpipe and 2.5" tubing to bolt to stock resinator flange. Goes for $750 canadian which is about $550 USD
Picture:
OBX/Forza Tuning:/b]This is a 4-1 SS header similar to the Ractive header in design. From first appearance the collector seems a bit shorter than with the Ractive header but has shown no ill affects. Comes with an EGR and O2 valve but again you will need to have the 2nd O2 bung wedled in behind the 2nd cat or have a MIL eliminator put in because this header does eliminate the primary cat. Goes for about 220-240 shipped from vendors like protegegarage.com and for about 200 shipped through ebay.
*note OBX does make a full catback system for the protege to complete their exhaust system for our cars*
Picture:
Best other pictures can be found on ebay: https://www.ebay.com (commissions earned)
As more info and more systems become available I will update this thread frequently. Like I mentioned before if you know of other systems available or information about any of the headers listed about please feel free to post.
TY
-Alex
edit:btw im not responsible for typos, im writing this as I check in guests here at the golf course =)
here we go....
Pictures to come:
Picture:
Picture:
Picture:
TY
-Alex
