its very easy.
sensor connect in the front fender lip by the tow point.
then run the wires along the side of the engine to the firewall.
Use a coat hanger and push them thru the firewall.
the fuse box has a spot already for auto dim mirror. just unbolt
fuse box, push connector in then you are done.
hardest part of install -> remove the driver's side door sill and
pillar cover to run the wires up. and along top of windshield
just stuff it under the cover.
pop out old mirror with a small flat head screw driver.
drop new mirror in and connect sensor wire and fuse wire.
power on car, let it calibrate and you are done
