- Mazda, 2017 cx-5, GT
Hello everyone, I know probably this question has been asked a million times here.
What you guys do with maintenance for your car?
I went to the dealer for the first 2 maintenance, I am not really satisfied with the service and price is high.
So now I just do oil change myself also chceck/replace the air/cabin filter myself. My car got 40,000 KMs now, what else I need to check if I don't go to the dealer or is that necessary if I go to some other auto shop to check.
Because I can't check the things under the car, do you guys do everything following the below?
Should I worry about these things?
* Inspect front and rear suspension components, ball
joints and wheel bearing axial play
* Inspect driveshaft dust boots
* Tighten bolts and nuts on chassis and body)
Thanks
https://cdn.mazda.ca/common/en/pdf/...289.484767929.1572484792-743731044.1571800643
EVERY 8,000 KM OR 6 MONTHS
* Replace engine oil and filter*1
* Inspect brake and clutch fluid, washer fluid, and
coolant level
* Inspect air filter
* Inspect function of all lights
* Inspect tire inflation pressure and tire wear
* Lubricate all locks and hinges
* Rotate tires
EVERY 24,000 KM OR 12 MONTHS
Includes 8,000 KM maintenance, plus:
* Inspect and clean brake discs and pads, front and rear
EVERY 32,000 KM OR 24 MONTHS
* Inspect fuel lines and hoses*2
* Inspect brake lines, hoses and connections
* Inspect steering operation and linkage
EVERY 40,000 KM OR 24 MONTHS
* Replace cabin air filter
EVERY 48,000 KM OR 24 MONTHS
Includes 24,000 KM maintenance, plus:
* Inspect drive belts
EVERY 56,000 KM
* Replace air filter
Thanks
coolant level
* Rotate tires
EVERY 56,000 KM
