Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: average coolant temperature on cx5
  1. #1
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    57
    I have about 430 miles on my 2019 2.5 liter cx5 and
    since were starting to get to warmer weather I was wondering something...
    If I start my cx5 cold and drive it about 3 miles with outside temp around 70- 80
    the coolant temperature guage is almost touching the 210 degree f.. mark............
    Is this normal ?? Seems kind of high........ and driving it under 40mph , during that
    3 miles....
    thanks for any replies........
  2. #2
    Registered Member
    Donated: $5
    CX-5 GT
    Join Date
    Aug 2014
    Location
    Ontario
    Posts
    544
    I'd verify that with OBD I I scanner. At that temperature both radiator fans would go crazy, and you'd hear that. Our '15 2.5L never goes over 200F, according to Forscan. I always thought that this engine runs really cool.
  3. #3
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,857
    Sounds totally normal. Ed
  4. #4
    Registered Member
    2017 CX-5 GT
    Join Date
    Apr 2017
    Location
    NJ
    Posts
    33
    Sounds normal, my 2019 2.5L turbo the needle is just a few notches below 210 degrees.
  5. #5
    Registered Member RepeatMazda's Avatar
    '16.5 CX-5 Touring AWD
    Join Date
    Feb 2018
    Location
    IL
    Posts
    116
    Normal. Most vehicles are set to run a thermostat in the 180-220 range with a majority holding operating temperature at 212.
    • 2016.5 CX-5 Touring AWD
    • 2018 Alfa Romeo Giulia Ti Sport Q4
  6. #6
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,396
    My old '08 CX9 ran at 193F.
    A readout from OBDII.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  7. #7
    Registered Member
    92 MX-3; 18 CX-5
    Join Date
    Jan 2019
    Location
    MN
    Posts
    49
    For the best fuel economy you want to reach operating temperature as soon as possible.
    Remember the coolant is under pressure so does not boil at 212*F. Assuming 18 psi even plain water will not boil until about 222*F. Coolant mixed with water raises the boiling point further.
  8. #8
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    291
    it keeps 200 to aprox 206 F.
    210 F sometimes just before thermostat opens fully.
    I havent seen more than 210.
  9. #9
    Registered Member
    Join Date
    Jun 2019
    Posts
    2
    Based on my research, i believe you would want it to go high as it would prevent carbon deposits into the intake valves.
  10. #10
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    57
    ok, thanks for all the good info........ just went for a 5 mile drive and it
    was at 206-208 degree mark, parked it and checked to see if the fans were running ..
    But both were not spinning .......... strange ? normal ??
    I might have to go for a longer drive to test .........
    temp out side was about 75 degrees, nice out........
  11. #11
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    291
    Its normal. The engine seems to easily maintain its internal temps at normal outside temps with less need for the fans vs other cars I've had.
    I hear the fans usually at 100F and higher outside temps.
    p.s.
    The thingie about carbon built is not relevant. This is engine coolant temp we are talking here, not valve, pistona and intake temps.
  12. #12
    Registered Member
    CX5
    Join Date
    May 2017
    Location
    Philippines
    Posts
    735
    Very normal. I get 212F daily driven but get 248F on the track after 4 laps of hard driving.
    But take note, I'm from the Philippines where the weather is basically HOT.
  13. #13
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    57
    went for a 10 mile test drive and coolant temp was still at 206-208 .. got home
    parked the cx5 , opened the hood and fans were still not spinning .........
    guess I'll go on a longer drive soon, plus summer is almost here , where it'll
    be hot and humid ...........which should get the fans spinning ...........
  14. #14
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,557
    The engine works at its most efficient when it is as close to melting as they can get it. They raise the boiling point of the coolant as high as they can until the incoming fuel is at risk of flashing. They block the inlet of the radiator with a shutter to speed up the heating process and then they confine the flow of coolant to the engine to stop it getting prematurely cooled in the radiator. When the coolant does eventually get to the radiator it then has quite a range before the cooling fan switch cuts in. The ram air effect when the car is moving is really effective.
    I can assure you that the fans will work. They usually come on when crawling in traffic but if you just want to test if they work, put the AC on full.
  15. #15
    Registered Member
    2019 Cx-5 sport
    Join Date
    Apr 2019
    Posts
    57
    thanks anchorman for the detailed reply.............
    I'll give the ac on full a try soon........... and check to see if
    fans spin up..........
Similar Threads
  1. Coolant temperature sensor
    By mazdasd in forum CX-5 Engine & Transmission
    Last Post: 12-15-2018, 12:17 PM
  2. MPH and MPG and average temperature
    By bosip in forum CX-5 General
    Last Post: 03-02-2013, 09:10 PM
  3. Coolant temperature sensor
    By Gustavo Lauffer in forum Mazda Protege
    Last Post: 11-12-2012, 01:07 AM
  4. Average Coolant Temperature
    By KrayzieFox in forum Mazdaspeed Protege
    Last Post: 11-22-2008, 11:27 AM
  5. Coolant Temperature
    By Deadend9009 in forum Mazda Protege
    Last Post: 11-09-2006, 08:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
