VersaTuner - tuning software for Mazdas
Results 1 to 2 of 2
Thread: Loose Center Arm Rest
  1. #1
    Registered Member
    cx9
    Join Date
    Mar 2012
    Location
    ca
    Posts
    28
    My daughter's 2015 Mazda 3 developed a loose/wobbly arm rest. Found out there is a pin that can work itself loose and come out from repeated opening/closing. Easy fix, sit in the back seat and remove the rear cover to the center console. There are 2 pins, one on each side. It is easy to see the loose pin, just push it back in. Easy fix in 2 minutes.
  2. #2
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,639
    Thanks for the tip. I typically open and close my center console lid about 5 times per week, on average. So far, so good.
    If the pin is not intended to rotate and it is metal into metal, a dab of Loctite 609 (green) on the pin will keep it in place for a long time.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
Similar Threads
  1. A Very Comfortable Center Console Arm Rest
    By David Paul in forum CX-5 Accessories & Appearance
    Last Post: 03-31-2019, 02:06 AM
  2. USB port in Center Elbow Rest
    By Caspan in forum CX-5 Infotainment
    Last Post: 04-09-2018, 02:50 PM
  3. New CX-5 Owner: Center Arm Rest Too Low
    By Lotto in forum CX-5 General
    Last Post: 02-11-2013, 12:52 AM
  4. Replies: 1
    Last Post: 07-07-2012, 08:56 PM
  5. Replies: 33
    Last Post: 03-01-2009, 08:00 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
