- 2010 CX-9
Are the front brake pads on this model oriented in inner and outer pads? Or are both pads the same and it doesn't matter which side of the rotor they are on?
the hardware clips that come with. The side away from the rotor has tabs that stick out past the rotor bracket. are they meant to be bent over against the bracket to help hold the clip in place or is this not required?
