Several evenings ago on an errand run I noticed a creaking noise from the suspension of the passenger rear wheel. It isn't apparent at highway speed but definitely noticeable at lower speeds and over a few bumps. I could also replicate it by opening the rear passenger door and bouncing the suspension. For me it was like fingernails on a chalkboard. I was able to get it into the dealership the next day. Within 5 minutes the service advisor showed me a technical service bulletin describing the situation perfectly. One of the rear springs is touching a rubber housing and making the noise. They had to order a new spring. This apparently only presents itself on the passenger side. I'll check in again with an update after the fix that will happen with an oil change in the next couple of weeks.
Sent from my Pixel using Tapatalk
