Ok ,so i just bought an msp for 1k, im pretty sure i know the answer, but i figured id consult you guys first. He said it has a brand new ebay turbo, but it went to 15psi, and started smoking. I put the scanner up to it, CEL light said PO303, so i checked the 3rd spark plug. Covered in oil. I looked down into the plug hole and i could see oil. Checked oil, level was fine and looked good, no creaminess. Start it, runs rough, when i put about 2 1/2k to 3k revs on, you can hear a knocking which sounds like the 3rd cylinder. Smokes when running. Looked under car and it seems to be coated in oil. I can see what looks like fresh oil by the head and top of exhaust shield. Motor toast right?
Sent from my SM-N910T3 using Tapatalk
