Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Unclog a/c drain and remove musty smell easily
  1. #1
    Registered Member
    2016 CX-5
    Join Date
    Feb 2016
    Location
    Buffalo , NY
    Posts
    287
    Hi, I searched and couldn't find a how to on this so I figured i do a write-up to help anyone in the same situation.....
    First thing I did was check the CX-5 service guide for unclogging procedure,
    there was none, but there was a diagram of where the drain hose was,
    it's behind the panel by the passenger left shin:
    Next step was to remove the plastic panel, it is very easy, pops right off.
    this is the rubber drain hose, you can see it's connected to a white plastic type barb connector:
    Then I followed the drain exit point to under the car and determined where the white plastic barb connector comes out from underneath, I jacked up the car and crawled to the approximate location and to my disappointment the drain was unreachable, it's behind a heatshield that is not easily removed or bent out of the way.
    So it was back to the top and try to unclog from inside the car,
    make sure to clamp the rubber hose first before pulling the rubber hose out from the barb connector
    make sure to get a bucket or container to catch the water:
    Remove clamp and if there's no water, spray compressed air up hose and be prepared for water to flow out, clamp if you need to empty catch container
    also, make sure to clear out any debris in the white barb connector:
    Next, if you have musty mildew smell, spray some Kool-It (from Amazon) to get some foaming action into the evaporator coils to clean out any fungus or bacteria that has accumulated due to stagnant water.
    Finally, just reassemble and reconnect the rubber hose to the barb, I added a zip tie just in case it clogs again, I wanted to make sure no water leaked thru the fitting.
    Also, check your cabin filter do make sure it's clean, replace if it's dirty, can't believe dealers charge $90 for this, scum thieves, how do they sleep at night knowing they rip people off
  2. #2
    Registered Member Kaps's Avatar
    Donated: $15
    CX-5 Touring 2016.5
    Join Date
    Aug 2016
    Location
    Lewisville North Dallas Suburb
    Posts
    2,126
    My toyota dealer charged me $20 for my corolla. But yes I will replace cabin filter on my own in My CX-5.
  3. #3
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,107
    I've washed mine 3x now.
  4. #4
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow Unclog a/c drain and remove musty smell easily
    Very nice write-up and thanks! I was wondering is it a common problem for Mazda as I've seen the same problem happened on CX-9 which eventually sized the blower motor. My other cars have never had clogged A/C drain issue and have never washed or cleaned evaporator once.
  5. #5
    Registered Member
    2016 CX-5 Touring AWD
    Join Date
    Nov 2015
    Location
    Bellingham, WA
    Posts
    63
    I've gotten some water dropping down by the left foot, passenger side when I run my A/C on the hottest of days (it never really gets very hot around here). This has been the first summer with the car. Always garage kept and never had an issue with leaf or pine needle build-up.
    I'll use this write-up to investigate the drain, so THANK-YOU!
    Off to buy a can of compressed air...
  6. #6
    Registered Member
    2016 CX-5
    Join Date
    Feb 2016
    Location
    Buffalo , NY
    Posts
    287
    Quote Originally Posted by B-ham Gary View Post
    You're very welcome, glad I can help !!! let us know how it turns out.
  7. #7
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,409
    Quote Originally Posted by Chris_Top_Her View Post
    I thought you were joking about this. I actually washed mine with a nylon brush and high pressure water from a hose. Filter material is actually pretty tough stuff.
  8. #8
    Registered Member PatrickGSR94's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    Aug 2016
    Location
    Memphis TN area
    Posts
    501
    One note about adding that zip tie... if it's clogged, the water wouldn't make it down to that zip tie anyway, right? Or if the white plastic piece is what's clogged, the water will eventually back up to the coils under the dash and probably overflow onto the carpet.
    Do you think I could just use my garage air compressor with air blow tool instead of that canned air junk? I could turn the pressure down if high pressure might risk causing damage to something.
    1994 Acura Integra GSR - 368K miles, a few mods
    2014 Mazda CX-5 Touring - 88K miles, the family hauler!
  9. #9
    Registered Member
    2016.5 CX-5 GT
    Join Date
    Sep 2016
    Location
    NA
    Posts
    265
    Quote Originally Posted by PatrickGSR94 View Post
    I think tomcat only suggested zip tie in case the barb connection was not water tight,
    i.e. if there's a clog in the future , water might start leaking from the tube / barb connector interface
    so zip tying it would ensure carpet/cabin doesn't get wet from water coming from the black hose.
    or if the black hose somehow unconnects itself via vibrations or bumps in the road, if it becomes loose any water from the AC will drip into the cabin. So the cable ties acts as 2 purposes, one to make sure the black hose is water tight to the white barb and to secure the hose to not come off from vibrations.
    I'm sure you can use garage air compressor to dislodge any debris just turn down the pressure, you don't need that much to remove clog.
  10. #10
    Registered Member
    2016.5 CX-5 GT
    Join Date
    Sep 2016
    Location
    NA
    Posts
    265
    Tomcat1446 you are da man !!!
    so after a long winter, started using the AC again for the first time and it smelled horrible !! at first, I thought it was just a cabin filter that need to be changed but after changing the cabin filter, the "locker-room" type foul smell was still there,
    thanks to your post, I was able to get to the evap core and spray some mildew killing Kool It and its smells brand new again, no more foul smelling mildew , One suggestion though, I recommend straightening out the rubber hose as straight as possible to get to the evap core to get to the source of the smell, otherwise there's a 90 degree bend at the top of the rubber hose that the Kool-It straw can't get passed..
    thanks bro, I love all your posts, you are a great contributor
    this shows the long straw that comes with the Kool-It so it can get deep into the evap core
    this was my cabin filter:
    my engine filter still looked brand new @ 20K, so didn't bother changing it yet
    just FYI guys , Amazon sells the combo cabin and engine filter for $17 shipped, PERFECT FIT ! I got the cabin filter with the activated carbon, no need to get expensive OEM, both parts are high qualilty, check the reviews
    can't believe dealer charge $79 for a cabin filter install service !!!! what a scam !!
    https://www.amazon.com/dp/B01N0BK7OV...ing=UTF8&psc=1
  11. #11
    Join Date
    Aug 2016
    Location
    Memphis TN area
    Posts
    501
    Yeah the cabin filter is pretty much the easiest thing ever to change. $79 at a $tealership does indeed sound like a scam.
  12. #12
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Quote Originally Posted by blackcx5 View Post
    Yep, tomcat1446 has been one of the best contributors for this forum! I like to read his many write-ups with detailed explanation and pictures!
  13. #13
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,799
    Blog Entries
    6
    I somehow missed this thread last fall. Nice writeup on clearing that pipe if it gets clogged.
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  14. #14
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    ... this was my cabin filter:
    The reason why your 20,000-mile cabin filter looks worse than your 20,000-mile engine air filter is because the cabin filter from factory is charcoal/carbon activated and looks little black and dirty even if it's brand new. If your cabin filter is non-charcoal white like those "genuine" Mazda cabin filter from US Mazda dealers, your two filters should look similar with the same mileage. Here is a picture showing the charcoal cabin filter I pulled out from a brand new 2016.5 CX-5 Touring in my dealer's showroom:
    Attachment 216190
    This's white non-charcoal Mazda genuine cabin filter (KD45-61-J6X) selling for as low as ~$17USD each on eBay:
    I usually insist using OEM parts all the time but sometimes I do use good quality aftermarket air filters used for engine and cabin. The filter combo from Amazon suggested by blackcx5 looks like an excellent alternative for us!
  15. #15
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,716
    Arrow Mazdda Cabin Filter Comparison
    Went to Mazda dealer yesterday and took more pictures on 2016.5 CX-5's new charcoal cabin filter from factory, Mazda genuine non-charcoal cabin filter with P/N KD45-61-J6X, and Mazda Value Products non-charcoal cabin filter with P/N KD45-61-J6X-MV:
    From the comparison picture shown above we can see those "genuine" Mazda cabin filters selling on the eBay are Value Products with white plastic frame instead of black. Value Products cabin filter is about $10 cheaper than Mazda Genuine Parts on list price.
Similar Threads
  1. Replies: 2
    Last Post: 09-29-2015, 07:54 AM
  2. Musty smell through vents when A/C is OFF
    By critic81 in forum CX-9 Lounge
    Last Post: 09-25-2014, 02:25 PM
  3. Musty smell
    By Swenny in forum Mazda5 Engine & Transmission
    Last Post: 04-17-2014, 10:28 AM
  4. Replies: 16
    Last Post: 08-01-2013, 10:28 AM
  5. Removing musty smell
    By Donas64 in forum Lounge
    Last Post: 07-02-2008, 01:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
