Hi,
I tested my brake fluid on my 14 '3 and the copper level is above 60 PPM with only 38k on the odo.
I wanted to do a flush with my next pad change which I will do doing myself.
My question is do I need an scan tool to purge ABS for bleeding?
I have only worked on Hondas and Toyotas in past and this was not needed so far ( 2010 or older).
Thank you,
Thank you,
