MaydayDown_Joey
- 2002 Protege 5
Questions:
- Is there anything *different* or troublesome about the system (non-abs)
- is there a disti valve or proportioning valve that can get air stuck in it.
- is there a very specific method to priming the master cylinder? (I have seen some cars that have bleed valves, etc)
- Any other advice
- Could it be the push rod behind the MS needs to be adjusted? I left the same setting it was on before. But the symptoms are the same regardless.
First and foremost.....
- Replaced defective master cylinder
- Replaced defective rear passenger side caliper
- bled the ENTIRE system
- NON ABS
- Issue that existed before both replacements still exists.
Issue: Engine on, pedal is soft and can go to floor, there is resistance but still travels too far. With the engine off the resistance is much greater and it does not go to the floor but you can tell it's not resistant enough. Also Ebrake can be pulled all the way to the limit, any less and you can spin the wheels, whereas before it was fine.
Backstory: I bought the car about a year ago, the fluid was low and I filled it and it seemed fine until recently then the master cylinder started leaking, I never let it get empty but I did fill it a few times. I was already working on one car so I couldn't work on the P5. The last time I drove it on my way home to work the pedal went soft, the car would stop but the pedal was pretty much at the floor.
Repairs:
- Replaced the master cylinder as it was obviously leaking from the rear seal.
- as I went to bleed the 4 corners I spotted the rear P/S caliper obviously leaking as it was covered in fluid.
- Replaced the caliper and bled the entire system, lots of air bubbles at the rear.
- Thought all was good and put the wheels back on started it up, and their soft.
- Rebled the rear caliper that was replaced to to make sure I got all the air out.
Today I'm going to re bleed all four calipers, I realize the obvious go to here is that there is still air in the system, but that's why I'm asking if there is something I could have missed.
- Any other advice
- NON ABS
Repairs:
