- RDX Aspec Adv.
Wtf - Poor Ninja will hate his CX-5 and this thread too. Lol.
And the 2.0L is not a sweet 4 banger engine, at elevated revs (4500+). An example of a truly smooth 4 banger engine that comes to mind is a 1.8L turbo by Mercedes, I'm sure other examples can be found.
The SR20DE in my Infiniti was a very nice 4-banger, and made nearly as much power with a much lower compression ratio and much simpler technology, as this SkyActive 2.0. A decade and a half ago. It truly is one of the best "workhorse" 2.0 4-bangers out there.
Then we have the Porsche 944S and S2's sweet 4-banger and larger 4-banger from the 80's with it's nearly 190, and its 208hp, respectively.
More recently, Honda's F20C/F22C.
No, the SkyActive 2.0 is not a motor that impresses me in the least, in any way, shape, form, or fashion, except that it required insane amounts of compression and direct injection and a trick 4:1 header to best my decade and a half old 9.5:1 2.0L Nissan motor with old cast-iron log looking manifold by a measly 10hp and 14# of torque. To me, that is the epitome of failure, from an engineering standpoint. Over 3 points higher compression. Much more advanced exhaust system (A full-blown race header, really), direct injection pushing fuel at 2900psi...and 10bhp and 14# torque is all there is to show for it!? Really!? As to fuel mileage, my G20 weighed 3,000#, and had a 4-speed slushbox. I got about 25mpg around town in it, and 31mpg on a road-trip to Kentucky by way of Louisiana. Slap a 6-speed auto in there, make it look less like a brick, and I bet it would best the Sky-active 2.0 for economy, even if you added 200# to the vehicle.
NOTHING about the 2.0 SkyActiv motor is impressive except in a masturbatory sense of showcasing technological capability.
Now, don't take this as a slam, as I love my CX-5, but I do not consider the 2.0 motor to be any sort of anything but a boat anchor with very expensive and well engineered high-tech parts, as far as its "value to posterity" goes. It's a showcase of capability in an engineering sense. Not in actual results. That said, I have read it is reliable, and if so, then that's good enough. It works, and it's not bad. However, "It works, and it's not bad" is not what legends are made of. The 2.5 stands out to me only because of its ability to make torque at such low rpm. However, it still doesn't impress me terribly, either, compared to other 4-cylinder motors that existed a decade before it was even a twinkle in someone's eye.
That said...I do love my CX-5, and the 2.5L motor is just fine with me provided all that expensive technology holds up for a decade or two and several hundred thousand miles like the motors that came before it do without a problem while making similar power.
