So in taking my Control arms out I realized I needed to remove this bracket to let the furthest rear portion of the control arm free. the furthest 2 bolts cracked free easily, and the third which actually locks the plate down had huge resistance so I went slow at it. Then it stripped (at least I thought.) but I wasn't able to get the bolt to come out so thinking its attached to the nut and flopping around in the control arm.
How can I go about repairing this. It appears cross member is hollow I won't have access to the bolt either.
I can weld alright so I am thinking I need to cut the bolt and get the nut either out of there or tacked somewhere its not gonna rattle around and then weld a new nut in place? I doubt this has happened to anyone else! but any input is appreciated. I don't want to change the crossmember or subframe. I just read on a FJ forum that I could drill 3 small holes around the bolt get the nut back into place and then weld it. After this I would still need to remove the bolt, and do thread repair on the nut and that may work. But it would be a better repair using a fresh nut in my opinion damn my luck.
[/URL][/IMG]
Rust central
Rust central
