I have already contacted them, but I have not heard back from them, yet.
Camber arms were too easy guys, I just added 35mm to the length and wollah, the JBR arms in my opinion are better as they have gussets
simply do what I did, sleeve and weld then tap the ends .
I showed you all pics and ive been running now for 15000ks zero issues
I'm buying it next month **** it. Just installed my auto exe end links. I've been holding off on an alignment because I was going to buy ne tires anyways, no point in spending $100 before I get the arm.
Yes they were long enough, it seems I remember you saying your set up at it's lowest is still slightly higher than they H&r so that may have something to do with it, and you mentioned a re/welded bracket or something so that might account as well. Also noticed yours were installed opposed, which may also have something to do with it as the angle is different.Chris are the end links long enough for you to use the Hard setting 2nd set of holes on the CS rear sway bar ? I found that on mine the links were not long enough and bound up, we re-manufactured the centre red section to make them a bit longer , now it fits perfect on hard setting and boy the hard setting makes a massive difference, but now im left with 2 red bars that sit in the glovebox heheh
