So I finally decided to bite the bullet and be the guinea pig for this upgrade. After numerous hours of research the verdict was that the 2012+ Mazda5 has an updated and reinforced rear suspension that mainly revolves around two main components: the rear springs with higher spring rate and the rear sway bar which is also thicker and higher spring rate as well. So I just ordered the following parts to do this upgrade to my 2006 Mazda5 and stiffen up the rear suspension without having to lower the height with lowering springs.
#CG37-28-011 Rear springs (2)
#CG16-28-151 Rear sway bar
#BP4K-28-156E Rear sway bar bushings (2)
#C273-28-012C Upper spring rubber mount (2)
The end links, lower control arms and cross-members are identical for all generation Mazda5 (2006-2013)
I just installed brand new KYB GR-2 shocks and I already have the two plates that hold the bushings to the cross-member (#BBM4-28-155)
I will update once I get the parts and get them installed.
