Looking for MSP rear calipers with brackets (doing OEM BBK) and JDP CF front lip for MSP (I know about MSPMichele's lip for sale, but she is taking time to find a box)
There's an even larger set up you can run, and is ALOT easier to source for a rear brake upgrade. Try a 98+ 626. There 20mm larger then the MSP set up, and should bolt right up. I havent heard of any MSP guy going this route. But after i used a set of MSP rear brakes on a probe i did a rear disc swap on, theres no reason it wouldnt work. But then you would need to do the calipers, and matching rotors. I believe the pad's are actually the same between both though.
