I am thinking of installing 2 gauges right under the dial controls, that one area in front of the shifter sometimes next year.
I have oil temp, press and Volt on my BMW and Miata just oil temp, since it comes w/ oil pressure.
for CX5, since lack of coolant temp (yes I know there is a sensor and warning light) I want to install that, the other one I'm thinking is just oil temp since I do not track or take corners that hard with this car, and most likely will check oil every month, so oil temp should be enough, it will not fit 3 anyways.
so oil temp or oil pressure? btw Audi comes w/ oil temp not pressure.
your thoughts.
your thoughts.
