2,200 to spend, need some advice!!??
himm34
06 Ms6
Hey guys, I need some help with a shopping list!! Like tittle says I have 2,200 I want to spend and need some advise so i can spend that money wisely!! Any help will be appreciated!!
performance wise, my list would be
1) Intake $200
2) Downpipe $300-500
3) Upgraded cdfp internals/new pump $300-700
4) Accessport $400-500
5) an exhaust manifold $200-400
6) Motor Mount $100 (awr mm)
7) J-Barone STS. $100
those prices are over estimated, but this would be my list.
First you need to take care of the car problems: Rear motor mount and Diff. mount (about 350$ used or 500$ new)
Oil Catch Can (used 80$ new 150$)
Next would be the performance parts:
Sort Ram Intake (125$-150$ used or 200$ new)
Turbo Inlet (125$ used or 200$ new)
Bypass valve(80$-200$ used or new 140$-300$)
Test pipe or downpipe (80$-400$ used or new around 600$ for a catted downpipe)
Cobb Accesport: (used 450$ or new 600$)
If you buy the Cobb AP the fuel pump internal is a must(400$ new)
And i would definitely go with some coil springs to get a better handling and look for the car,my choice would be Eibach Pro-Kit(150$ used or 300$ new)
There's a lot of these parts available (used) in the "For Sale sections" of different MS6 forums.
Have fun and keep us posted on your mods!
***Cobb Accesport: (used 450$ or new 600$)
The bit about the internals is not fully true. I'm bolted less a exhaust manifold, and at 20 psi I see constant small dips to around 1500psi in winter (0 degrees c and below). The worst i have recorded was 900 on a -27 day.
its different for every owner it seems... so this will be at his own discretionary when to upgrade. I don't think he will often see such low temperatures, plus if your listing the rear diff mount as a problem, which again its hit and miss, the internals should be first.
If you going to push your car, it would be ideal just as a precautionary measure. But then lets not beat around the bush, if you wanna push this car and never worry again buy a good set of connecting rods...
For that you're right!
Latest posts
