What I'm getting at is your post is not that specific, and it could be alot of things. Cheap semi-metallic pads squeal, its just a fact of life, but not sure what pads you used. Pads tend to squeak when replaced on existing rotors sometimes. Shims also make a large difference in a good or bad way. My factory shims were causing a loud pop every time I would accelerate off the line, so I ditched them when I put new pads on. My ceramic pads only have a built in shim, adhered to the back of the pad...and that is all I am using, no other shim. Also, if your brake hardware kit is not re-installed correctly, it will not pull the pads away from the rotor when you take your foot off the brake.
Give us more info to help with the issue.
