Is your turboxs downpipe/racepipe installed yet? If not, you might want to wait on the CBE until you hear what that mod does to your exhaust. Then decide if you want the CBE and what kind you would like.
With mine, the downpipe/racepipe made the stock CBE much louder and the catless dp/rp introduced a really bad drone at 2,500 rpm when cruising or when decelerating through that rpm range. I fixed it by putting a big 3 inch straight through reso in the racepipe section.
Others (on some other boards) who are running catless dp/rp's seem to really like the Magnaflow CBE when coupled with this combo. It is, I believe, the same as the Mazdaspeed "official" CBE for our cars, just rebranded by Mazda. It is well-known for its ability to kill the drone.
But I can't personally vouch for it because I'm happy with the stock CBE and the racepipe reso solution. That combo will really wake the car up from a power standpoint and aftermarket CBE's do not make more power, IMHO, if you are running the stock K04 turbo, because the stock CBE has a higher flow rate that the maximum exhaust discharge rate from the turbo.
