2007~2015 CX-9 Dim brake lights
Peckerhead
2007 Mazda CX-9
I have a 2007 CX-9 Grand Touring. I don't know how long this problem has been around because I don't see my brake lights all that often. I noticed a couple weeks ago that the brake lights on the CX-9 are incredibly dim. I was driving behind my CX-9 tonight and you can barely tell that the brakes are on even at night. Is this a common or even known problem? And if so, how can I fix it?
I would prefer to not bother with the dealership service department, but I will go there if I have to.
Thanks...
I don't have that problem. Best to try to check with a voltmeter whether has the full 12V is should have or try to replace one fo the lights. Maybe they have gone bad.
do you guys have some aftermarket accessories installed that might be grounding out the lights?
Is there anyway to turn it off or disconnect it just to check if that is not the issue? With time some things can corrode themselves or connections can become corroded. Just a thought, might not even be the issue, but better to start somewhere.
I finally gave in and took the truck to the mechanic for diagnostics. They traced the problem to a faulty brake switch (Part #L23266490). They found that 12 volts was on the input side of the switch, but only 6.6 volts were on the output.
I'm having the same "dim brake light" issue on my 2007 CX9 GT, and neither of the local dealers have the part in stock (or even agree on what the part is).
How did you replace it, and does anyone have a parts diagram for this.
Thanks
Quick follow up to the replacement brake light switch. It was the culprit in my case and the part # was the same as above (Part #L23266490). It is a light green electrical switch with a white plastic rod extending at one end and is located above the brake pedal. To remove turn the switch unit counter clock wise approximately a quarter of a turn and it will come loose. then unplug the wires from the top and replace with new unit. There is a panel above the pedal assembly that needs to be removed by removing two plastic center pull type rivets to get access to the switch. One additional note: the white plastic rod is is adjustable (by pulling it out or pushing it in) and needs to be at the proper length setting to make the brake light come on and off when the brake pedal is pressed, otherwise the lights will either not come on or will always stay on. It took me some trial and error to get this right. I probably could have compared the length of the old switch to set length on the new one but didn't think of it at the time.
#67-210 in the linked diagram.
http://www.jimellismazdaparts.com/s...ukey_driveline=0&ukey_trimlevel=0&modelYear=0
Fellas, I had the same issue - bad brake switch. I have 2010 CX-9 Touring which is over 5 years old and around 35K miles. Initially, I noticed that the high mount 3rd brake light did not work. I bought a new light (around $150) and replaced it. Still the same. Then, I replaced the cord that connects the light to the wiring. Still no luck. Then, I noticed that the old light and cord actually worked but were emitting very dim light not only from the 3rd brake light but all brake lights for that matter. So I gave up since I can't work with voltmeter. A friend of mine measured and it was only less than 4 volts coming into the light which helped him figure out that it is the switch. The switch is around $30 and about an hour of work. Now all lights illuminate brightly.
I want to thank everyone who has contributed to this thread. I pulled great value from your information. I have a 2012 CX9 and discovered (by another driver yelling at me on the Interstate that I had no brake lights - of which I was thankful for) that my brake lights were very dim. Because of the accurate detail of this thread I called the dealer and explained my dim brake light issue AND that I had found a forum where other CX9 owners had the same issue. I even gave them the part number! They had me come in and sure enough it was a faulty brake light switch. Unlike some folks on the thread who could tell via a voltmeter that their switches weren't getting enough voltage on either the input or output side, my voltage was reading fine on both sides. That made the dealer doubt my claim of the faulty switch, but when they troubleshot everything else and could not find another cause they replaced the brake light switch anyway and sure enough that fixed it! And the part number on my invoice was, yep you guessed it, L23266490!
... but when they troubleshot everything else and could not find another cause they replaced the brake light switch anyway and sure enough that fixed it!
Hopefully they didn't charge you labor for all the time they wasted troubleshooting when you walked in and told them what was wrong from the start.
Fixed it for free!
Thank you to all who posted above, you saved me a lot of time and aggravation. I was pretty sure going in to this that the third brake light was not bad/dead. From the comments provided I looked more closely and realized they were all dim and the third light could just be seen in the extreme dark. With this confirmation, I knew I was on the right track. I went right to the switch as described above and removed it without even checking with a voltmeter. I realized the switch could be opened, so I popped it open and used some contact cleaner on it. Once reinstalled, the brake lights all work and are brighter than ever! Done in 30 minutes.
Fixed it for free!
Good to know that it can be disassembled and cleaned. I LOVE fixes like this!
Was it easy to pop open? Did you see any obvious crud before you used the contact cleaner?
Sometimes you can run the risk of breaking off a plastic tab that holds it all together. Or my favorite was always when you disassembled something facing in the wrong direction, and all the pieces, springs, balls, etc. fall out, creating both a treasure hunt, and a fun little puzzle... (cryhard)
Saved the day!
This thread saved my day! I had the same problem - top center brake light went out first, then the other brake lights became very dim. I was able to fix it for the cost of some electrical contact cleaner.
Getting the unit out is easy, but opening it is a little tricky. And be careful of the parts inside - they are pretty loose, and felt like they could fall out if I turn the two halves upside down. My unit had some good buildup of something in there around the contacts. I took the contact cleaner, wet the ends of of a few qtips, and polished it up. I also hit up anything metal I could easily clean up for good measure.
Here are some pics of the part. First, the green switch located above the brake:
attachment.php
The the switch itself opened. I highlighted what looked like the contact areas:
attachment.php
Lastly, I experienced the same thing as Aron in Toronto with regards to the plastic rod that protrudes from the unit. If you push on it or pull on it with any amount of force, it will lengthen or shorten. Well, suffice it to say that I inadvertently adjusted it when removing and prying apart the switch. After I first reinstalled the switch, the brake lights didn't work at all. Then I took it out, shortened the rod, tried again, and viola! bright brake lights!
This was very helpful. I was having the same issue in my CX9. My fix was some what simple. After having trouble trying to get the green piece apart I remembered what you guys were saying about the white plunger. So I pushed it in two clicks and now the lights are all bright! So maybe theres no real need to do a disassembly of that part. Only need to make an adjustment.
G'day from Sydney. I had exactly the same issue today and came across this thread. It saved me lots of money and hassles. My mechanic who did a regular servicing today was unable to repair and told me that I might need to replace a relay or circuit which will cost minimum hundreds of dollars.
I just signed up to say thanks and add little information with regard to the white rod mentioned above. The green piece was a bit hard to disassemble as you need to pry up both sides at the same time. Also, the click-push type holder is quite fragile. I cleaned inside with contact cleaner spray. Mine had some build-up inside. After assembly, brake light remained on regardless of the brake pedal, then I remembered the white thing. Mine was too short to reach the pedal so it remained on. I needed to extend it but the white rod did not extend even though I applied quite substantial force. It could be only me but I had to pull up the white lever (not the white rod) with a pin near the connecter while shortening or extending the rod. Please see the photo. I hope this helps someone in the future.
Love how people are still finding this thread useful after all these years! (y)
Posted a link to this thread in our Resources section.
One of the best and most informative vehicle forum posts I have ever found/used.
My 2010 CX-9 failed inspection because 3rd brake light not working. As I did troubleshooting, I thought the regular tail lights looked dim as well when braking (not nearly as bright as they should be if lights were already on). Found this post when googling symptoms, then rechecked 3rd brake light in the dark and saw that it was barely illuminated, so not a broken light, but rather an electrical voltage issue and this thread pointed me to the right location.
Based on other comments, I removed my switch and opened up to clean contacts. Switch is definitely tricky to open up as mentioned in previous post because you have to pry from both ends at same time to release clips. I ended up just breaking open the clip retainer on one side to make it easier. I originally only cleaned the stationary contacts because I hadn't read through all the posts and I was rushed to fix. Reinstalled and lights were improved, but still not working right.
After looking at excellent photos provided by Mako925, I took apart again and used precision screw driver to scrape residue on the moving contacts on the plunger side along with WD40. I also pried them out a bit so they would make a stronger contact point when engaged with the stationary contacts. Put back together and everything worked perfectly.
I would like to add that after inspecting the switch, that the white plunger is not actually "adjustable". It is made to be either fully extended (if the spring is not fatigued and can still extend it all the way) or fully inserted (by the brake pedal) to the stops where it comes into contact with the stationary contacts. However, when you take it apart and move the plunger around to clean the moving contacts, you could risk it not being reseated properly before putting the switch back together. The white plastic tab on the side is a guide that helps control the travel of the plunger via a small metal clip and those pieces can get misaligned while cleaning.
The bottom line is that these pieces need to be placed back in precise position before popping the switch back together. I suspect that the posters who had issues probably pulled on the plunger until it got back into position to get it working again. Because of their posts, I noted that my plunger wasn't fully extended before I snapped it back together and then I saw it was because the movable contacts were striking the plastic that you can see in Mako925's photo. I used my precision screw driver to "tuck" these contacts in behind the plastic guide and push it down all the way (and fully extending the plunger).
I am so happy that I was able to fully restore everything in only about 20 minutes (following an hour or so of research) and didn't have to pay hundreds of $$ to the dealer trying to find the issue. I would also point out that if you aren't comfortable popping open the switch, you can buy one on Amazon for only about $28 for the OEM part or you can get an after market switch for much less (I bought one as a backup for $15 in case I need to fix this again). For that price, I figured I would just replace it with a new one. Just search for part L23266490.
