justanothermp5
Banned
- Rust Bucket
i had to cut a shitload out of my bumper, i regret doing it, i should have just moved the IC core back further
hmmm... i havent found many IC kits that require removing the fogs or doing more than trimming very small portions off the bumper tabs. look up a bunch of install threads for FMICs as a starting point, lots of people run into problems (like this one) and maybe they posted a solution.
I had the same problem, I cut the fogs out, problem solved. lol.
just move it.Alright well I fooled with it a little bit more and it seems like he mounted it to the hood latch support. To do that I will have to relocate the AC condensor loop that is now between the core and hood latch support. How do I do this safely? I'm looking at the MAM install and it doesn't give much detail.
do it once, do it right. ive left the car uncomplete overnight for simpler things, dont be ashamed of a quality job no matter how long it takes. glad to hear youre having more luck. and as for the clamps, as long as you tighten the worm ones down really tight ive never had any issue
well you can tighten the worm gear clamps with a ratchet too you know
i think its like a 6mm or something lol i had to use a couple on mine when my T bolts stripped out
they work fine
Well after a little cutting here and there, this b**** is ready to rock! Only minor problems as of now.
-Boosting around 5-6 pounds (seems a bit low) if youre on the stock WG, this is normal, especially after a FMIC install. exhaust will increase boost sometimes, but FMIC generally drops it
-BOV not working all the time (have to adjust the spring)correct, and make sure youre on a dedicated vac source or on the brake boost.
-Fog lights not working (I think I forgot to reconnect the harness)
-Intercooler core not sitting perfect (but hey it's aftermarket, right?)boo hoo.
Overall I'm pretty satisfied with the way everything sits, and once I fix the problems mentioned above + a good tune then it should finally run well.
