FlyinHawaiian
- Mazdaspeed Protege #1460
Yep, I wasn't sure, but I'll just go with the extra long/open-ended lugs
Eibach makes some great and beautifully cnc machined spacers, im running 30mm spacers on my offroad truck, the way eibach sets it up, i retained my stock lug studs, no need for extended studs or anything funky. they cost me around 120 for a set of 2 spacers.
I highly rec them, many options with them
when i googled them just now autoanything has em cheap
any updates on this? looking for some 10mm spacers
Yeah, what you have to do is buy a set of spacers that come with extended studs and throw them on. You just slide the spacer on over the studs and then the wheel on top of that. If you go back to a set of wheels (like I do for winter) which have a larger offset (stock RH's = +55mm, snow wheels = +45mm) you need to take the spacer off and make sure you have open-ended lug nuts and a deep socket to put on.
Looks like spacers for all 4 corners is going to run between $200-300
its cool dude. If you get the 10mm spacer, you can use the stock lugs. Its only if you go to something with an offset larger than +55mm.
Just to clarify... if you use the 10mm spacers to mount your 55mm offset stock wheels, you WILL need to replace your stock lugs (the threaded "bolts") with longer extended lugs. But you will be able to use your stock lugnuts. If you later change your wheels out to wheels with a LOWER offset (45mm for example) then you will need to use an extended lugnut or go back to your shorter oem lugs, which I would not recommend doing as the holes in your hubs that they press into will get sloppy if you change them out too often.
Does anyone now wats the offset on our stock racing harts?
Understood. Looks like I'll have to add some RAYS flat-black extended lugs to the order.
+55mm. The 10mm spacer will bring that offset to +45mm. I think I read that +42mm is about the furthest we can go without negative camber or rolling the fenders...
Just got mine!
HUBCENTRIC FTW!
On the note of studs, how exactly do you replace them? I've never really looked into it, so how time consuming is it?
Please do a "HOW-TO" on installing the new studs when you get around to them please. I'd love to learn from your mistakes... (crazy)
