sherman banks
I've been doing my research for the last hour or so here on the forums and hopefully can get some explanation to help diagnose my problem.
Car is a 2003 Protege 5 with around 70k. The other day, a very high pitched squeal started coming from the front right side of the car. It's not the belts as they have been an issue previously and I'm very familiar with how annoying they can be and this only happens when the car is moving. It really sounds like something is stuck in the brakes but in a brief inspection yesterday (without the wheel off), it didn't look like anything was there. No indication of wear on the rotors either. My first thought was the wheel bearing was going out but in reading here, it appears it could also be the brakes (seized caliper?). Is there any way to tell if I do have anything stuck in the brakes? And is replacing the pads/rotors on these a difficult job? The sound is not always continuous and at first was mostly an issue when turning left, but now it's squealing just going straight. Anyways, I can provide more info if necessary but I just wanted to see what some of you veteran P5 owners think.
Thanks in advance!
Thanks in advance!
