hey guys new here, been searching around for a solution to no avail.
I was driving my fiance's car the other day and when I pulled up to a stop sign and it simply died and wouldnt start.
I checked and it has spark, and the fuel pump is coming on, but I have not verified I am actually getting flow. i am pretty sure I am though since I check the plugs and one was a little wet after trying to start it for a few minutes.
So next I thought maybe a bad head gasket. I checked compression and heres the weird thing.
I am getting 60 psi across the board, so then I thought timing belt. I looked inside the oil filler cap and can see the cam spinning when the car cranks so it seems that the timing belt is in tact.
Could it have jumped time? I keep hearing about these tensioners, could it have gone bad enough for the car to jump time? After I verify fuel this weekend I think I am going to tear the timing belt apart and replace it. But I just wanted to see what you all think. I appreciate the help.
Thanks,
Chuck
Thanks,
Chuck
