CorkSport.com is MAZDA PERFORMANCE!
Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 191
Thread: Spare Key & Fob Programming for Mazda5
  1. #61
    Registered Member
    Join Date
    Oct 2009
    Posts
    1
    Thanks for all the information posted.
    My fob (mazda5 07) is often unresponsive, and I believe this is down to a low battery.
    Will replacing the battery myself cause any issues with the programming?
    I've found the batteries on eBay for $7: http://cgi.ebay.com/ebaymotors/ws/eB...m=260294721053
    Seems a lot simpler (and cheaper) than purchasing another key. Anyone know about this?
    Thanks in advance
  2. #62
    Registered Member
    Join Date
    Jun 2009
    Posts
    13
    Quote Originally Posted by particlekeeper View Post
    I just ordered a spare key from Ebay
    First of all: I was not able to program it for my car :-(
    As I needed it as replacement for a broken key (which still worked), I just used the housing and put my electronics into it.
    All keys together:
    left the new uncut key, in the middle my original spare key and my broken key to the right.
    I suppose it's due to the different circuits in the keys. As you can see one has the number JX331BA3802C, the other ends with 5802C
    Basically they look identically, despite the battery contact and the IC:
    One Chip is labelled MH860-DM98519K the other one MH860-DM98663K.
    For completeness I took a picture of the numbers printed onto the key:
    I'll go and ask the Ebay dealer if he has a key having a circuitry with the number my key has.
    At least it was a cheap solution to get a "new" key. Cheaper then getting one from Mazda.
    Maybe if you take it to the dealer they can force program it?
    I had the same idea buy some key from ebay and let the dealer program it if its possible even if it isnt the same part nr.
  3. #63
    Registered Member
    Join Date
    Dec 2009
    Posts
    1
    Red face Mazda5 fob won't unlock doors (works otherwise)
    Quote Originally Posted by Procrustes View Post
    I made a 3rd key for my 2007 mazda 5...
    I bought a transmitter fob off ebay (~$30). I programmed it using instructions in the PDF file. You can program up to 3 fobs for your car.
    -Note that although the PDF specifies it is only for 2006 vehicles below a certain VIN, it worked fine on my 2007.
    I bought the RFID key blank from the dealer (~$10?) and had it cut at the local locksmith ($5). You or locksmith will need to tap in the small roll pin to attach key to the fob if it's not already attached. I then programmed the key using instructions in the GIF file. You can program up to 8 blanks this way.
    Good luck!
    Hey, I'm new to MazdaForums, but I managed to find my way here. I have a 2006 Mazda5 I bought a few months back. it had only one fob. I bought a fob off ebay ($40) and I think I'll have a local locksmith do the cutting and programming ($65). The orginal fob works (mostly), but will not unlock the doors. Any idea's what might be wrong? How to fix it? Thanks!
  4. #64
    Registered Member Davebert's Avatar
    Join Date
    May 2009
    Location
    Montreal, Canada
    Posts
    267
    Quote Originally Posted by RalphSpurt View Post
    Is that for all the doors or just the sliding doors? It is a know problem with the sliding doors not unlocking, there is a service bulletin on this from Mazda.
  5. #65
    Look Mom, A Real Clutch! coolmazda5's Avatar
    Donated: $15
    2008 Mazda5 5MT Sport w/ Popular Package
    Join Date
    Oct 2006
    Location
    Wawa Land (NE US)
    Posts
    5,201
    Can your locksmith do the programming? You need 2 keys in order to program a 3rd one (safety reasons).
    And yes, let us know about the doors (nothing, partial?), Does the red light come up when pressing any button?
    - 2008 Mazda5, 5MT Sport, Stormy Blue Mica, Popular Package, Aux Input, TPMS, The Thule Roof Rack Works, MAZDASPEED Shift Knob
    - Past: 2006 Mazda5, 5MT Sport, Carbon Gray, Popular Package, OEM Fog Lights
    [How to Search & Post]
  6. #66
    Join Date
    May 2009
    Location
    Montreal, Canada
    Posts
    267
    I bough this key with build in transponder for under $10US including shipping from here:
    http://www.dealextreme.com/details.dx/sku.16640
    The only problem with it was the key needed a little filling to work properly and shipping from Hong Kong took just a little over 2 weeks. My M5 came with an after market start with its own remote so it was a bulky having the switch blade key and the after market remote in my pocket. I already have 2 working switch blade keys and I was able to program the key first shoot with the following procedure:
    1. Insert first working transponder key into ignition and turn it to the on position, wait 3 seconds and remove key from ignition.
    2. Within 5 seconds insert second working transponder key into ignition and turn it to the on position, wait 3 seconds and remove key from ignition.
    3. Within 5 seconds insert new key into ignition and turn it to the on position. If car icon in between the speedometer and tachometer stops flashing and than turn off your new key has been programed, if not repeats all 3 steps.
    Though I pass this along and happy new year to everyone.
    Davebert
  7. #67
    Fat, dumb, & happy. CaptainSpalding's Avatar
    Mazda 5
    Join Date
    Dec 2009
    Location
    In Denial
    Posts
    46
    Quote Originally Posted by Davebert View Post
    Hi Dave,
    I bought the same key you did based on your post. Although it appears to have the same profile as the original keys it won't fit in the door or the ignition, either before or after being cut. Can you please tell me where you had to file it to get it to work?
    TIA,
    Spalding
  8. #68
    Join Date
    May 2009
    Location
    Montreal, Canada
    Posts
    267
    Quote Originally Posted by CaptainSpalding View Post
    Hi Dave,
    TIA,
    Spalding
    Hi Spalding, I should have made it more clear. The area that I filed was the straight edge that runs the length of the key. If you look carefully or have a caliper to measure the distance between that straight edge and the ridges you will notice that distance is larger on the original key. I took a small file and file that straight edge down on both side of the key. Just file a little at a time on both sides making sure to keep the file flat don't take off too much and test fit the key often.
    It took me around 5 minutes and 3 or 4 test fits to get the new key to work. Since a picture is worth 1,000 words here is a picture that I hope you will find it useful.
    Good luck and please update your progress.
  9. #69
    Mazda 5
    Join Date
    Dec 2009
    Location
    In Denial
    Posts
    46
    Just what I needed! Thanks. I'll post with the results.
    Update:
    It worked like a charm. I used a very fine triangular jeweler's file and removed a tiny bit of material from both sides of the key as indicated by Davebert above. It didn't take much - only about sixty strokes per side. This photo shows another angle of the key. The surface to be filed is highlighted in red.
    (Be sure to file both sides of the key.)
    Once the key fit into the ignition, the programming sequence described above worked the first time. Thanks everyone.
  10. #70
    Registered Member p5T's Avatar
    Join Date
    Apr 2005
    Location
    Fairfax, Vermont
    Posts
    162
    Davebert
    I just programmed two transponder keys for my 2005 Mazda6 this way. (Bought two keys on evilbay and local hardware store cut them both for free)
    03 P5 - ES Pkg, Profec e-01, EMB, DO H2O Injection, T3, Turbo XS bov, Illumminas, RB Springs, Progress 22mm rear bar, Falkens 205/45/16
  11. #71
    Registered Member
    Join Date
    May 2010
    Posts
    1
    First time post
    My wife and I bought a 5 because we liked it best for getting around town with a new baby. I bought a third transmitter to use in case we lost of our two originals. I followed the service bulletin posted earlier in this thread.
    I was able to program the third transmitter --- but it will not start the car.
    I can't figure out what I am doing wrong? Is there a programming step I could have missed it? The key cut wrong?
    Matt
  12. #72
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,523
    Quote Originally Posted by Matt Mazda5 View Post
    Matt
    Is this the method u are using?
    Mazda's I have owned over the years. (boom07)
    80' Mazda GLC SPORT MT - sold
    81' Mazda 626 DX MT - sold
    81' Mazda 626 LX AT - sold
    82' Mazda 626 DX MT - sold
    82' Mazda 626 LX AT - sold
    85' Mazda 626 LX MT - sold
    87' Mazda 626 GT Turbo MT - sold
    85' Mazda RX-7 GSL-SE MT- sold
    87' Mazda RX-7 Turbo 2 MT - sold
    91' Mazda Protege LX MT - sold
    92' Mazda MX-5 Miata MT - sold
    93' Mazda MX-3 GS-V6 Special Edition MT - sold
    00' Mazda 626 LX-V6 MT - sold
    02.5' Mazda Protege5 MT - sold
    06' Mazda 5 Touring AT - sold
    13' Mazda CX-5 Touring AT - sold
    14' Mazda 3i Grand Touring MT - sold
    15' Mazda CX-5 Touring AWD AT - sold
    03' Mazda Protege5 AT - sold
    09' Mazda Mazdaspeed3 GT - sold
    16.5' Mazda CX-5 Touring AWD AT - current
  13. #73
    Registered Member
    2006 Mazda5 GS 5MT
    Join Date
    Aug 2009
    Location
    Winnipeg, Canada
    Posts
    151
    I just finished doing this with a new fob on my Mazda5. Keep in mind that there are two parts to the programming. One part (the GIF image in the first post) programs the key for the immobilizer. The other part in the PDF is for programming remote portion of the fob. You can program a fob to just open the doors without being able to start the car.
    2006 Mazda5 GS 5sp MT - Current
    1999 Ford Taurus SE Sedan - Given to Nephew
    1988 Buick Regal Limited - Donated
  14. #74
    Registered Member
    Join Date
    Oct 2005
    Location
    Illinois (U.S.)
    Posts
    729
    ...I was able to program the third transmitter --- but it will not start the car...
    You have to program the transmitter, then the chip. Two different processes. Follow the instructions just below your post, and of course welcome to the forum!
  15. #75
    Registered Member bud9899's Avatar
    2008 Mazda5 Sport
    Join Date
    May 2010
    Location
    GA
    Posts
    10
    I used the instructions in the 1st post with a 2008 mazda5 no problems. I also added a regular mazda transponder key($20 delivered) with an ID of ID4D-63 with no problems. The key looked like Davebert's key but didn't need any additional filing just needed cutting. Thanks for posting the instructions. Now we got 3 keys with remotes and 1 regular key for my key ring. HooRay
Similar Threads
  1. Programming a Spare Remote for Mazda3
    By goldwing2000 in forum Mazda3 How-To
    Last Post: 03-25-2018, 02:10 PM
  2. Mazda5 Spare
    By dann & misti in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 06-20-2015, 09:35 AM
  3. Will full size spare fit in the spare tire well?
    By breiland in forum Mazda Protege
    Last Post: 11-14-2010, 04:02 AM
  4. Replies: 1
    Last Post: 06-28-2004, 10:04 AM
  5. Replies: 0
    Last Post: 06-28-2004, 01:30 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
