I am having a TPMS problem on my new 2007 Mazda3 GT. The TPMS (Tire Pressure) warning light (!) turns on when I drive. It will flicker, and then stay lit, turning off during the drive and then sometimes turning back on. All four tires are holding pressure correctly. 32 psi when cold rising to about 34 - 35 psi when warm. The problem only occurs after the car has been driven for a period of time. The dealer said that a diagnostic scan indicated that the TPMS module was reading each tire pressure correctly, but the ID codes for each wheel sensor were not registered in the module. The dealer "registered" each wheel sensor and sent me on my way. The same TPMS warning light problem returned later the same day. No change. Do I have a defective wheel sensor or a defective receiver module? The dealer seems to want to use the "keep bringing it back and we'll check it" method. The problem is that most of the time just shutting off the engine for a few minutes resets the warning light only to have it return after the car is driven. Any ideas? Thanks.
