LinuxRacr said:Manifold repaired. I don't have the time or money to recoat it. The flange was also machned to be flat once again. Here are a few pics of the gastly manifold:
I only need water lines now, and I'm set.
LinuxRacr said:Where is Fast-turbo located? The manifold was stripped of it's jet-hot coating. That's why it looks so tore down. It won't be on my car for long probably though. I have plans for tubular cast.
what's the difference?LinuxRacr said:The circled gasket is what I need it looks like. While I'm at it, I can put my JDM Mazdaspeed lower temp thermostat back in:
Jeph said:My symptoms were pretty severe.
I couldn't hold a constant fuel pressure at idle.
I was bucking, spitting, and overall driveability went down the tube after the tune had been fine for months.
I know that it can be less severe, and not be able to provide enough fuel up top no matter how much you add. It would just feel like you hit a brick wall in the upper rpms when your pump can't keep up anymore.
