- MP5
hey what goes into the bung and is it supposed to be pretty loud? I got injen cai and a obx header! and im not sure if this is right but... when im at like 3k rpms it vibrates bad- any suggestions>?
ghettobubba2001 said:for now i have a broken O2 sensor in there :0 ( in that hole) ( and i didnt want to overtighten the part where the header connects the midpipe- should i tighten it all the way that i can?
ZoomZoom03 said:which version of the MAM midpipe do u all own...and in regards to choosing, i want one with a hi-flow cat, but do u recommend the stainless stell one or the mild steel one??
rednecks_r_us said:When I installed my MAM midpipe it vibrated against my crossmember and the bottom of my kartboy shifter and the heatshield.
To fix this I installed AWR motormounts, Kartbou exhaust hangers, bent the hangers on the midpipe to create clearance from the crossmember & removed the heat shield.
No more noises or vibrations under the car. I got the hardest AWR (manual tranny )mounts and now my dash vibrates. So even if you have a stick shift car get the auto mounts from AWR they are a little softer.
I did front and both side inserts..ZoomZoom03 said:ok im gonna order the AT AWR motor mounts, now did u do the full front and rear set, or just the front ones?? from all my reading it seems the rears are quite a pain to do. i already ordered the Kartboy hangers.
