More strange noises! Argh
Humvee
I've noticed since it's been cold that for the first 10+minutes of driving, when I turn the wheels say...make a right or left turn onto a street and accelerate while the wheels are turned, there's a very loud engine rattling noise. This noise is not present when I accelerate at a light with the wheels straight.
Any ideas?
If you had an older car, I would say it was your C.V. Axles, but since the car is new and seems to be temperature dependant... I have no idea. I would be interested to know if anyone does know the answer... Good luck.
When I had my car in last, my dealer found a leaking cv axle seal and had to replace it...
might be worth a check...
It's most likely the axle. I had a 90 Accord that had the same problem. Knocking sound when I turn only. My bro-in-law is a mechanic and had to change the axle. Your car should be rather new so most likely it's a leak like he said above.
