2 2000VRsex Member May 22, 2008 #1 b4 I put in my gauges in (yes they are mech) what should the oil psi max out at? I dotn want the max psi of the car to be greater than the gauges lol. thanks
2 2000VRsex Member May 23, 2008 #2 bump or any modds wanna move this to performence iono figrue move ppl in this one,
A AusOrion Member : Mazda SP20 sedan (MP3) May 23, 2008 #3 Max oil pressure is around 60 psi. You should be around 20 psi at idle and then 60 psi at 3k rpm and beyond.
2 2000VRsex Member May 23, 2008 #4 AusOrion said: Max oil pressure is around 60 psi. You should be around 20 psi at idle and then 60 psi at 3k rpm and beyond. Click to expand... Thanks! so my 100psi gauge should be perfectly then.
