2017~2024 CX-5 Chirp Noise from Automatic Transaxle on 3-4 upshift - Bulletin 05-005/23
“The challenge with four-cylinder deactivation is that an engine running on two cylinders is more likely to cause vibration. Mazda’s breakthrough solution to compensate for this is to use a fulcrum inside the six-speed SKYACTIV-DRIVE automatic transmission, helping ensure seamless transition between two- and four-cylinder operation.”
Yep, the pendulum damper is built into the torque converter and because of its size there is no room for the multi plate lockup clutch set that the non CD cars have.
I'm so glad I opted for the 2017 instead of the 2018 back in early 2018 when I bought my CX5. Mazda dealer had a bunch of new 2018's on the lot and a prior model year 2017 on the lot. I read about the CD and I had a strong gut feeling that it could turn out to be problematic. So I bought the 2017 model year which didn't have CD and dealer gave me a price break on the new 2017 as it was a model year old already. I paid like $23k for a brand new 2017 CX5 Touring.
SO MANY problems have been emerging from the CD. Cracked heads and now failed transmissions/torque converters. All to save maybe 1/2 mpg, if that. I hate that the EPA/CAFE has forced this stupidity on manufacturers and they come up with ways to increase MPG with technology that is not proven to last but proven to fail and over complicate systems. They made a reliable car/drivertain in a problematic drivetrain.
CD sucks! 🤬
And yet there are many CX5 with CD that have more miles than 2017 models and still driving.
I think latest gen of CD is very mature. Many manufacturers use it not just Mazda
Yep, the pendulum damper is built into the torque converter and because of its size there is no room for the multi plate lockup clutch set that the non CD cars have.View attachment 324785
Hey folks, could really use some help here.
I’ve got a 2020 Mazda6 Sport that fits this exact problem and year/model found in the TSB.
I attempted to bring it into a Mazda dealership at 60,211 on the odometer at the same time this TSB came out. They sent me out the door with merely a trans software flash for shift points and reset the trans learning. Problem obviously persisted.
Brought it back around 66K miles and they now say the trans needs replaced at $5700. Mazda corporate offered $2500 “after warranty assistance” but both they and the dealer refused to fix the problem under warranty even though I initially came in at just 211 miles past the 60K powertrain warranty.
I didn’t have this TSB in hand at the time of either visit and now that I do, I asked the dealership to reconsider a warranty trans replacement since the iron powder contaminating the ATF didn’t just start at the time I brought it in - it’s likely been slowly destroying the trans for thousands of miles and I should not be on the hook for such a flaw when I brought it in at 60,211.
Shop manager still has not called me back about it and Mazda corporate won’t return my calls either.
Any advice on how to negotiate this with the dealer and/or Mazda corporate? Extremely frustrating situation…
Also, wondering if having a trans flush would help alleviate some or all of these symptoms, or is the damage already done from the iron flake contamination and a flush would be a waste $$ or maybe even make things worse?
Firstly the ATF in SkyActive auto transmission can’t be flushed unless the shop has a special ATF cooler adapter and knows how to do it correctly. It isn’t an approved method by Mazda and the Mazda dealers won’t do it this way. If you do ATF drain&fill 3X with ATF filter cartridge replacement my guess is it won’t help as the damage has already done (hence your transmission is having symptoms).
My suggestion to you is to get rid of your Mazda6 when you still can.
Latest posts
