Unfortunately no
I confirm : in my 2018 Signature, presets 1 and 2 are programming seat and ADD. Great feature!
I checked the manual of my CX-9 GT '17 this is what I found:
Driving Position Memory*
The desired driving position can be called up after programming the position.
The following driving positions can be programmed:
- Driver’s seat position (seat slide, height adjustment, seat recline). Refer to Seat Operation on page 2-5.
- Active driving display (display position, brightness level, display information). Refer to Active Driving Display on page 4-29.
Hopefully one day Mazda will add the left/right mirrors positions to the seat programming. I really hate to setup my mirrors every time after my wife uses it.
My wife and I are about to pull the trigger in a new GT.
Does the seat memory also save the heads up display setting?
My wife is short, and I am not
Yes it does...in my 2017 Signature when you open the door to which keyfob was programmed to the memory seats, the height level adjustment of the HUD adjusts to whichever it was set to. I just wish the side mirrors adjusted as well but Mazda got rid of that feature!
Wait, so depending on which key fob you use, the car will automatically adjust to that setting. Like I can program one key fob for me, and another to my wife?
Correct.
When programmed and you open the door, all settings are adjusted to the fob settings.
But is not automatically done, you need to press the Set button in the seat and then press de unlock button in the FOB to save the settings. It also works independently of the seat memory buttons (1, 2). For example, if you store a setting in the number 1 of the seat the key fob will keep the settings when it was programmed. So if you want to keep the same settings for the fob and the memory 1 button just remember to update both when storing any new adjustment to your settings.
Not in our 2011 with the crappy key fob and no seat memory hahaYou could do that on the 1st Gen CX-9....
