Just got an email flash from VLEDS saying they are introducing a new line of compact LED headlight bulbs, 3,000 lumens each.
Text of their notice:
For years we have been trying to replicate the size and shape of a standard halogen bulb while still achieving sufficient light output. LED technology has steadily improved in this time period and has finally allowed us to do just that.
We are proud to introduce our Micro Series LED Headlight System.
Utilizing six highly efficient LED chips along with heat pipe technology means the design is thermally safe while still producing 3000lm measured output per bulb (the equivalent of a 35W HID setup).
Key features include:
Safe for use in sealed headlight applications (caps can be reinstalled)
Low profile design eliminates fitment issues
Push/pull collar indexing adjustment
IP68 waterproof turbo fan enclosed in 6063 aluminum shell
Molded driver with integrated OEM connector
Available in 5K and 6K color temperatures
2 year warranty
Metal core PCB's quickly transfer heat away from the diodes and directly into a 6063 aluminum heat sink via the copper heat pipe. Inside is a specially designed waterproof turbo fan that pushes air through the top and bottom of the heat sink.
Indexing is one of the most important features on any plug in style LED headlight and the Micro Series is revolutionary. The days of using an Allen wrench to tighten a set screw are gone! Just push the collar down, twist, and pull it up to lock it into place.
20% PRE-ORDER DISCOUNT ACTIVE NOW
ARRIVING LATE JUNE
Available in the following base types:
H1, H3, H7, H8, H9, H10, H11, H16, 9005, 9006, 9012, 880
Might be a solution for all the halogen-equipped vehicles. I really like their stuff.
Link they provided.
