e4UmHWsv3HGQ
My 2009 Mazda 5 "sport" stopped blowing air through the front blower the other day.
I did a bunch of research, want to share what I learned here because I didn't find the answers so easily in other places.
My car has automatic climate control (9 or 10 blower speeds with an LCD display), and has a 2-speed rear vent between the front seats which seems to blow cold air only. Parts diagrams indicated different parts for manual (never seen it) vs automatic climate control, and draws a distinction between those which have "rear ventilator" and those which do not. I guess I've got rear ventilator, but am not familiar with the more upscale models to know if there are additional rear vents missing from my car.
Many cars use a resistor pack to control fan speed. These are typically for cars which have 4 fan speeds. Speed 1, 2 and 3 run the blower power through a resistor block that's installed in the air ducting for cooling purposes.
That's NOT how my 5 works. My 5 has a MOSFET fan driver, not resistors, in the ducting in passenger footwell. 3 wires attach:
The fan is powered from the other end via relays and whatnot. The MOSFET box in the passenger footwell controls fan speed by modulating ground.
Accordingly, the blue/orange wire always shows voltage, because it's coming from the fan.
The path is:
If the fan is "on", but not running because the MOSFET is bad, the blue/orange wire should be at relatively high voltage (10+V). That voltage is coming through the fan motor coils and not finding its way to ground.
A working MOSFET box pulls that blue/orange wire to ground, causing the fan to run.
The MOSFET box takes a PWM input signal on the skinny blue/yellow wire.
The PWM signal switches on and off really fast. Whenever it is ON, the Blue/Orange wire is pulled to ground.
So, the Blue/Yellow wire (PWM signal) voltage (average) should be inverse of the Blue/Orange.
At low fan speed, the PWM signal should read around 2-3V and the fan should be around 8-10V. As the PWM voltage approaches 12 (really it's just on "more of the time"), the fan (blue/orange) voltage should approach zero (grounded "more of the time).
Putting a test lamp on the PWM signal might not be safe. I don't know how much current the climate control is intended to source. It's probably safer to just use a voltmeter on the blue/yellow wire.
Inside the MOSFET box there's a thermal fuse intended to pop at 133 degrees C. It's secured to the heatsink with a clip, screw and thermal grease. It's the first place that the PWM signal goes once it enters the MOSFET box (before it gets to the actual MOSFET drivers in the box).
The fuse was bad in my unit: Mazda # CE4961B15, stamped HB180BP4M is a $100-ish part. For a quick check, pop the plastic lid off the MOSFET box and follow the circuit trace for the PWM input signal. It disappears under the board into a through-hole component (the fuse) and re-appears on the opposite side of the board at an identical spot. There should be continuity between these points.
Fixing the fuse requires unsoldering one of the MOSFETs and the fuse from the board inside the box, because they're screwed to the heatsink and then the board is soldered down on top of them. The other MOSFET screw is easy to reach, so it can stay attached to the board.
A high-wattage soldering gun is probably appropriate here, because these are big components and several spots need to be desoldered at once.
The fuse should be just a few cents. The interesting thing about this fuse is that, unlike others I've seen, this one has a ceramic body. Most axial type thermal fuses have a metal body which is connected to one of the legs. Because this fuse is mechanically secured to a metal heatsink, that difference might be important.
The fuse is marked with the following:
Edit: This guy shows how to get to the MOSFET: http://www.youtube.com/watch?v=jgxP6s-_JqM
He and the Mazda parts counter both refer to it as a "resistor"
- blue/yellow signal wire
- blue/orange fan wire (heavy gauge)
- balck ground wire (heavy gauge)
The path is:
- Battery
- Underhood Fuse(s)
- Underhood Relay(s)
- Front Blower Motor
- MOSFET box (in via Blue/Orange wire)
- Ground (out via Black wire)
Code:
12X UMI
133C N3 <- There's a "degrees" symbol (133 degrees C) there, but I don't know how to type it here.
2A 250V~
3.5A 125V~
<PS>E JET
