duration and overlap...both have a large effect on idle vacuum...so, in general, ideally i would want to slightly increase idle rpm to make up the difference in vacuum...what i'm seeing, is that simply opening the throttle plate slightly through its stop screw...i can increase the airflow...on its own, thats not exactly what i need (as i need air velocity, not just higher flow, adjusting this will only increase volume but won't necessarily help...
Also, digging around on club protege clarified some things...that with the above info, makes a lot of sense and i might have found a way to fix my problem very quickly...
My IAC must be working...the IAC controls idle throughout the entire start up process...it opens up the bypass, lets more in for cold starts, and since its 'stepped' by the computer...is able to maintain a predetermined idle speed (roughly 1500 rpm for the first minute or so, slowly dropping as the engine heats up)...I'm having this fine, it does this, and everything is normal...
the cam aspect is the other variable...with more than 4 degrees of overlap, and with the 252/254 duration at .006" (forget off the top of my head, but not important)...i'm creating too little vacuum at idle...and it causes the quick drop...The IAC will eventually step through some measures to get that back to normal, but its taking enough time to often result in a stall...and the computer doesn't seem to be in any hurry to 'write that down'...
our TB's have 2 adjustments...on is simply a physical set screw to set the minimum throttle plate position...no electronics, nothing...the other is an adjustment (can't quite tell from the pictures) on the side of the IAC...mazda says NEVER touch the plate screw...but what i can tell, and others have gotten it to work with adjustable gears, is that i can slightly raise the minimum position on the TB...and that will then let the IAC step around it better...i'm seemingly right at the very limits of the IAC (for 750rpm that is)...and i don't need to raise the idle speed, just need to control the amount of air getting in at the current speed...if that makes sense...the current set up is very close to ok, according to the computer, as within a few seconds it reigns in the idle and hold it fine at 750...but the lack of vacuum as the engine descends in revs, and the speed with which the IAC tries to take over...simply isn't right for a set idle of 750rpm...even the clubprotege guys were saying the only time to adjust that plate screw was with a very modified intake manifold or aggressive cams, otherwise it'll just race the engine...
I'm going to carefully mark the current screw position when i get home...and tighten it very slightly to open the TB up a little...again, without manipulating the ecu, i won't be getting any additional rpm...i'm only physically allowing more air in regardless of what the IAC decides to do, and how slowly it decides to react...
